CAR Scheduler Alert - Physical Log size 20000 is too small
neilo
We have a clients CUCM Server that has produced the following alert:
%UC_CAR-2-CARIDSEngineCritical:  %[ClassID=***********_car8_6_2_22900_9-7[ClassMsg=Dynamic Server  Initialization failure.][Specific-Msg=WARNING! Physical Log size 20000  is too small.  Physical Log overflows may occur during peak  activity.  Recomme][AppID=Cisco CAR  Scheduler][ClusterID=][NodeID=padeobxtela01]: Pay Attention. This alarm  does not compromise data or prevent the use of the system.
AppID : Cisco Syslog Agent
I'm aware that ideally I need to expand the Physical Log file size but I'm not sure where this is changed.  Can anyone point me in the right direction?
Best Regards
slashdots
Well you cannot expand the Physical Log size. If you need these CDR Logs, I reccomend you Exporting them to an SFTP Server.
If you do not really need all those CDRs just lower the days CUCM will keep them.
Loginto CAR -> System -> Database -> configure automtic purge
hope that help
slashdots
hope that help
That's great, thanks for your help.......really appreciate it.
Besr Regards
