05-23-2013 08:24 AM - edited 03-16-2019 05:28 PM
I've searched hi & low and don't seem to be able to find a catch-all template (with all the fields) used for bulk administration of Cisco phones with Call Manager. Would anyone by chance know where I could find this please?
Thank you so much
Kind regards
Mario
Solved! Go to Solution.
05-24-2013 06:32 AM
You can build a phone then perform an export of that phone and the csv file will include all fields.
HTH,
Chris
05-23-2013 09:53 AM
You need to build your own templates.
Chris
05-24-2013 04:28 AM
Thanks Chris, maybe I wasnt clear, apologies.
What I mean is a spreadsheet for example, with all the available default headers.Obviously yes your correct, I do need to fill in and build my own details out but just as a starting point, I was wondering if there was anything which showed every available header option, as I'm after a certain parameter?
05-24-2013 06:32 AM
HTH,
Chris
05-29-2013 02:06 AM
Thank you Chris
05-29-2013 03:56 AM
Great. If this answers your question please mark it answered.
HTH,
Chris
