Cause i = 0x80AC - Requested circuit/channel not available on Incoming Calls
gabiulici
Beginner
Beginner
I am facing problems with incoming calls on a MGCP PRI Gateway. Some of the incoming calls get disconnected with cause code: Cause i = 0x80AC -
Requested circuit/channel not available - Destination address is non-ISDN
I noticed that this happens only on  one specific port/channel.
*Dec  2 09:11:23.816: ISDN Se0/0/3:15 Q931: RX <- SETUP pd = 8  callref = 0x7900
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18397
                Preferred, Channel 23
        Calling Party Number i = 0x1181, '499417906xxxx'
                Plan:ISDN, Type:International
        Called Party Number i = 0x81, '25xx'
                Plan:ISDN, Type:Unknown
        High Layer Compat i = 0x9181
*Dec  2 09:11:23.816: ISDN Se0/0/3:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xF900
*Dec  2 09:11:24.592: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x003E
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Calling Party Number i = 0x0081, '256251xxx'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0049697603xxxx'
*Dec  2 09:11:24.756: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x803E
*Dec  2 09:11:26.748: ISDN Se0/0/3:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0600
        Cause i = 0x8090 - Normal call clearing
*Dec  2 09:11:26.772: ISDN Se0/0/3:15 Q931: TX -> RELEASE pd = 8  callref = 0x8600
*Dec  2 09:11:26.828: ISDN Se0/0/3:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0600
*Dec  2 09:11:27.488: ISDN Se0/0/3:15 Q931: RX <- SETUP pd = 8  callref = 0x7800
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA18398
                Preferred, Channel 24
        Calling Party Number i = 0x1180, '499417909xxxx'
        Calling Party Number i = 0x1183, '499417900'
        Called Party Number i = 0x81, '2221'
*Dec  2 09:11:27.500: ISDN Se0/0/3:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xF800
        Channel ID i = 0xA98384
                Exclusive, Channel 4
*Dec  2 09:11:27.500: ISDN Se0/0/3:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xF800
        Cause i = 0x8091 - User busy
*Dec  2 09:11:27.712: ISDN Se0/0/3:15 Q931: RX <- RELEASE pd = 8  callref = 0x7800
*Dec  2 09:11:27.732: ISDN Se0/0/3:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xF800
*Dec  2 09:11:28.588: ISDN Se0/0/3:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0200
*Dec  2 09:11:28.616: ISDN Se0/0/3:15 Q931: TX -> RELEASE pd = 8  callref = 0x8200
*Dec  2 09:11:28.668: ISDN Se0/0/3:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0200
*Dec  2 09:11:30.456: ISDN Se0/0/3:15 Q931: RX <- SETUP pd = 8  callref = 0x7700
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA18399
                Preferred, Channel 25
        Calling Party Number i = 0x1180, '499417906xxxx'
        Called Party Number i = 0x81, '2575'
*Dec  2 09:11:30.468: ISDN Se0/0/3:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xF700
*Dec  2 09:11:30.468: ISDN Se0/0/3:15 Q931: TX -> ALERTING pd = 8  callref = 0xF700
        Progress Ind i = 0x8088 - In-band info or appropriate now available
*Dec  2 09:11:32.084: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0x803E
        Progress Ind i = 0x8488 - In-band info or appropriate now available
*Dec  2 09:11:32.084: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0x803E
*Dec  2 09:11:33.200: ISDN Se0/0/3:15 Q931: TX -> CONNECT pd = 8  callref = 0xF700
*Dec  2 09:11:33.328: ISDN Se0/0/3:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x7700
*Dec  2 09:11:34.300: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0x803E
*Dec  2 09:11:34.304: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x003E
*Dec  2 09:11:38.892: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x003F
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98396
                Exclusive, Channel 22
        Calling Party Number i = 0x0081, '25625xxxx'
        Called Party Number i = 0x80, '00491736693xxxx'
*Dec  2 09:11:39.060: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x803F
*Dec  2 09:11:48.416: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0x803F
        Progress Ind i = 0x8482 - Destination address is non-ISDN
*Dec  2 09:11:50.504: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0x803F
*Dec  2 09:11:50.532: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0x803F
Do you by any chance have a fractional T1?
Can you try to bounce the T1?
Is it always with the port?
Try No Mgcp/MGCP on this guy.
ANy way you can forward the sh run, or at least the part with the mgcp/ccm-manager configuration?
Please Kudos/rate if this help!
Dennis Mink
Advisor
Advisor
Probably is caused by the way the ISDN B- channels are being address and probably in which order
reason code:
80AC: The remote equipment cannot provide the channel that the user requests, due to an unknown reason. This problem is usually temporary.
as per:
http://www.cisco.com/en/US/partner/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
Can you check the channel selection on your MGCP Gatways PRI interface and see if it is bottom up, top down, alter it and test again.
Please remember to rate useful posts, by clicking on the stars below.
Ajay Viswanath
Beginner
Beginner
Do you notice this behaviour only on inbound calls or outbound calls as well.
You can test this in oubound call by changing the order in the gateway and check if the error seems to follow only with a particular channel.
You won't be able to select the channel for inbound call as it is selected by the provider.
If you notice issue only on a particulat channel..then you can busy out that channel and check if anyother channels are affected as well.
I have seen this issue before where bouncing the controller will give it a temproary fix.
Rate if it helps
Ajay
I manage to find what was the problem. The problem was I do not have enough PVDM on the router and from the last E1 the first 10 channels work k and the rest cannot receive calls.
Have a nice day
Recognize Your Peers
