I try to understand the CCA process and the CLI result when an auto-attendant is configured.
On the CUE card, I dont' find mapping for option part (script parameters), only prompt management.
For example, option 0=> extension 202, option 1=> extension 203..etc
ccn application autoattendant aa
description "Auto Attendant"
enabled
maxsessions 4
script "aa.aef"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "false"
parameter "allowExternalTransfers" "false"
parameter "MaxRetry" "3"
parameter "dialByExtnAnytime" "false"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "businessSchedule" "systemschedule"
parameter "dialByExtnAnytimeInputLength" "4"
parameter "operExtn" "998"
end application
It is CCA which re-write aef script as CUE editor ?
Thank
