ccm 11.0 upgrade not enough space issue
osw200051
Hi All,
I try to upgrade ccm 11.0.1.20000 to 11.0.1.22900
But failed and the failed message is not enough space.
I try to load "ciscocm.free_common_space_v1.3.k3.cop" to ccm successfully.
Then try upgrade process to 11.0.1.22900 still failed, not enough message still present.
Does anyone help for me?
Thanks all
Aseem Anand
You need to free up some space by adjusting the low and high watermark to 10 & 20.
Follow the steps suggested in the document below:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200581-Procedure-to-Adjust-WaterMark-in-RTMT-of.html#anc6
PS note: Change it back to the default values once you are done upgrading.
Aseem
(Please rate if useful)
Thanks Aseem,
The problem was solved after your advise.
