CCM 4.13 query
michaeljbyrne
I am trying to find out how many times a route pattern is used. Is there a query I can run?
Jaime Valencia
No, there are no reports for how many times a RP is used, if you have CAR, you would only get info on the calling and called numbers, not which RP was used.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
