CCM 7.0 unexpected reboots
Hi guys,
we have an MCS-7825-I3 with CUCM 7.0.2 that has started rebooting a couple of times a day the last few days.
I can,t find anything wrong with it in the logfiles and syslog...
could it be a hardware issue?
i'm glad the issue is resolve!!
7 Replies 7
Vipul Jindal
hello,
you might need to check the below bug
CSCti52867
MCS 7816-I4 and 782x-I4 READONLY file system
thanks,
Vipul Jindal
The documents state the affected server are 78xx-I4 versions... mine is an I3 version... does this effect the 7825-I3 version as well?
whats the output for
show hardware
show status
thanks,
Vipul Jindal
admin:show hardware
HW Platform       : 7825I3
Processors        : 1
Type              : Intel(R) Core(TM)2 Duo CPU     E6400  @ 2.13GHz
CPU Speed         : 2130
Memory            : 2048 MBytes
Object ID         : 1.3.6.1.4.1.9.1.746
OS Version        : UCOS 4.0.0.0-9
Serial Number     : KQRFNXL
RAID Version      :
RAID Firmware Version:  1.18.83.00
RAID BIOS Version:  6.0e.00.00
BIOS Information  :
Vendor: IBM
Version: IBM BIOS Version 1.38-[G9E138AUS-1.38]-
Release Date: 01/07/2008
RAID Details      :
LSI Logic IR Configuration Utility 2.00.15
Background command progress status for controller 0...
IR Volume 1
  Volume ID                               : 5
  Current operation                       : None
  Volume status                           : Enabled
  Volume state                            : Optimal
  Physical disk I/Os                      : Not quiesced
admin:show status
Host Name    : rbbh-cucm-pub
Date         : Sat Sep 10, 2011 20:19:56
Time Zone    : Central European Time (Europe/Sarajevo)
Locale       : en_US.UTF-8
Product Ver  : 7.0.2.20000-5
Platform Ver : 2.0.0.1-1
Uptime:
20:19:57 up  2:50,  1 user,  load average: 0.04, 0.08, 0.09
CPU Idle:  99.00%  System:  01.00%    User:  00.00%
  IOWAIT:  00.00%     IRQ:  00.00%    Soft:  00.00%   Intr/sec: 995.10
Memory Total:        2073780K
        Free:          26832K
        Used:        2046948K
      Cached:         869296K
      Shared:              0K
     Buffers:          67484K
                        Total            Free            Used
Disk/active         27474844K       15830252K       11365464K (42%)
Disk/inactive       27474876K       26001344K          77888K (1%)
Disk/logging        95602984K       70077044K       20669496K (23%)
The system restarts a few times and then gets booted to the BIOS. It even reboots in BIOS sometimes. Then it works fine for 8 - 10 hours and crashes again.
hello,
can you please try running the recovery disk and does the scan check manually to check if we get any errors.
thanks,
Vipul jindal
Hi Vipul.
It ended up being a HW issue... we ran an RMA and got a new server from Cisco.
Thanks for the help.
