CCM Backup status result
andrew.brazier
Level 4
Level 4
Is there a way I can get CCM to notify me of the backup results? At the moment I wither have to check manually (v6) or use syslogging to trap a success or error.
Craig Dyer
Level 3
Level 3
Andrew,
     Can you not use RTMT alert, CiscoDRFFailure there is an e-mail distribution list option on a per alert basis.
     http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_1_1/rtmt/611-rtmt-admin.html
Does this meet your requirements?
Craig
(Please rate helpful posts)
Craig Dyer
Level 3
Level 3
Andrew,
Craig
Hi  Craig,
Thanks for the tip, RTMT seems able to tell me that a file failed to copy which is a small improvement over the syslog messages as  Iat least get a status check for the CCM 6 cluster as well as the CCM 7 ones.
Ideally what I'd like is a proper backup tool for CCM, one that does GFS archiving with full logging and notification functions. I can dream. : )
