CCM Command is not recognized (Trying to activate a MGCP Voice gateway)
jocadesa123
Beginner
Beginner
I am having problems while tying to configure a MGCP gateway
I have installed the DSP modules, the VIC2-4FXO card and everithing is beeing recognized in the Inventory as well as in the show diag
but when stating to configure  the MGCP part in order to configure the ccm-manager:
Router(config) ccm
I get a "invalid input detected" and also unrecognized command" when mgcp comand is typed
What could be the problem?
6 Replies 6
saif musa
Enthusiast
Enthusiast
What is the result from " show version " command ? did you have appropriate image installed inside the router to work with DSP modules and voice card ?
This is the  "show version" information...
USCOR-VG-05#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 13:24 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
USCOR-VG-05 uptime is 2 hours, 4 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FJC1949A1R0
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2901/K9 FJC1949A1R0
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc None None None
data None None None
NtwkEss None None None
CollabPro None None None
The commands are certainly context-sensitive whether in user, exec or config modes, so use "?" and see if you can find the command which you trying to type.
Maybe that helps
Can you put snippets of the cli when you are entering the commands (mgcp, ccm-manager mgcp, do show mgcp, do show ccm-manager etc) in config mode.
Please rate if you find this helpful.
Aeby
Aeby
I had a similar issue after my 4331 failed and I attempted to load the previous config on the new 4331. The license needs to be re-homed (may be able to be done from Cisco licensing portal or smart license manager, I had to contact TAC to engage licensing team). Once they issue the LIC file it gets copied to bootflash: and then installed (license install <WORD.LIC>
Once it's installed I think the EULA needs to be accepted (license accept end user agreement) and if it's disabled in the config, you need to remove that line (no license boot level uck9 disable) then wr mem and reload.
After that, it should show as YES enabled in show license feature and as uck9 in show version under Technology Package License Information.
Once the license show active/enabled, UC global config commands like MGCP and ccm-manager will work instead of saying "invalid input.
Very frustrating process.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/csa/command/csa-cr-book/csa-l1.html
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
lubkenmsd
Beginner
Beginner
Recognize Your Peers
