CCM Group
mightyking
Level 6
Level 6
Hello Everyone,
I am in weird situation.
I have two CM Groups (GM_CM1 and CM_GM2). Each groupe has 2 Subs as follow:
GM_CM1 = Sub_1 and Sub_2
GM_CM2 = Sub_2 and Sub_1
When the phone is registered with Sub_1 (GM_CM1) through the appropriate device pool everything works.
The problem starts when the phone is registered with Sub_2 (GM_CM2). All calls work except 911. A message stating "Your call can not be completed as it is dialed". The weired thing is as soon as I register the phone with Sub_1 everything inclusing 911 calls work.
Below is the trace for a local call using Sub_2 which works as well as a 911 call through the same Sub_2 which fails.
Not I see the Forbidden and No Found error message in the 911 call trace but don't understand why it works with Sub_1 and fails with Sub_2.
Working Local Call Through Sub_2
2015/02/02 13:59:33.471|SIPL|0|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468914^10.16.244.26^*|1669307|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|INVITE
2015/02/02 13:59:33.472|SIPL|0|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468914^10.16.244.26^*|1669308|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|100 Trying
2015/02/02 13:59:36.743|CC|SETUP|53236359|53236360|18882061454|+15146027093|+15146027093
2015/02/02 13:59:36.748|CC|OFFERED|53236359|53236360|18882061454|+15146027093|+15146027093|SEP002414B33E40|SIP_Trunk_NACC_CUSPIntA5_CPODC1
2015/02/02 13:59:36.748|SIPT|53236360|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|5060|3,100,63,1.468927^10.16.244.26^*|1669342|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|INVITE
2015/02/02 13:59:36.751|SIPT|53236360|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|32785|3,100,230,1.253711^10.116.129.109^*|1669343|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|100 Trying
2015/02/02 13:59:37.625|SIPT|53236360|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|32785|3,100,230,1.253713^10.116.129.109^*|1669351|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|183 Session Progress
2015/02/02 13:59:37.626|SIPT|53236360|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.130.14|5060|3,100,230,1.253713^10.116.129.109^*|1669352|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|PRACK
2015/02/02 13:59:37.628|SIPT|53236360|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.130.14|64432|3,100,230,1.253714^10.116.130.14^*|1669353|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|200 OK
2015/02/02 13:59:37.633|SIPL|53236359|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,68,19.1^*^*|1669354|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|183 Session Progress
2015/02/02 13:59:37.634|SIPL|53236359|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,68,19.1^*^*|1669355|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|SUBSCRIBE
2015/02/02 13:59:37.735|SIPL|53236359|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468931^10.16.244.26^*|1669356|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|200 OK
2015/02/02 13:59:37.739|SIPL|53236359|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468932^10.16.244.26^*|1669357|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|NOTIFY
2015/02/02 13:59:37.739|SIPL|53236359|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468932^10.16.244.26^*|1669358|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|200 OK
2015/02/02 13:59:45.304|SIPT|53236360|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|32785|3,100,230,1.253721^10.116.129.109^*|1669386|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|200 OK
2015/02/02 13:59:45.305|SIPT|53236360|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.130.14|5060|3,100,230,1.253721^10.116.129.109^*|1669387|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|ACK
2015/02/02 13:59:45.311|SIPL|53236359|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,230,1.253721^10.116.129.109^*|1669388|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|200 OK
2015/02/02 13:59:45.439|SIPL|53236359|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468940^10.16.244.26^*|1669389|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|ACK
2015/02/02 13:59:49.020|SIPT|53236360|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.130.14|64432|3,100,230,1.253725^10.116.130.14^*|1669407|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|BYE
2015/02/02 13:59:49.024|SIPL|53236359|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,230,1.253725^10.116.130.14^*|1669408|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|SUBSCRIBE
2015/02/02 13:59:49.024|SIPT|53236360|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.130.14|5060|3,100,230,1.253725^10.116.130.14^*|1669409|a041e180-4cf1c918-15c16-1283740a@10.116.131.18|200 OK
2015/02/02 13:59:49.025|SIPL|53236359|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,230,1.253725^10.116.130.14^*|1669410|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|BYE
2015/02/02 13:59:49.059|SIPL|53236359|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468946^10.16.244.26^*|1669411|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|200 OK
2015/02/02 13:59:49.064|SIPL|53236359|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468947^10.16.244.26^*|1669412|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|NOTIFY
2015/02/02 13:59:49.065|SIPL|53236359|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468947^10.16.244.26^*|1669413|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|200 OK
2015/02/02 13:59:49.199|SIPL|53236359|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468949^10.16.244.26^*|1669416|002414b3-3e4000df-e57ec560-93c4e455@10.16.244.26|200 OK
2015/02/02 13:59:49.202|CC|RELEASE|53236359|53236360|16
Failing 911 CALL Throught Sub_2
2015/02/02 13:59:51.270|SIPL|0|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468953^10.16.244.26^*|1669427|002414b3-3e4000e0-fcac178b-dd5d511e@10.16.244.26|INVITE
2015/02/02 13:59:51.271|SIPL|0|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468953^10.16.244.26^*|1669428|002414b3-3e4000e0-fcac178b-dd5d511e@10.16.244.26|100 Trying
2015/02/02 13:59:56.938|CC|SETUP|53236361|53236362|012720215004|911|911
2015/02/02 13:59:56.946|CC|OFFERED|53236361|53236362|012720215004|911|911|SEP002414B33E40|RP_NACC_911
2015/02/02 13:59:56.961|CC|SETUP|53236361|53236364|15148581256|911|911
2015/02/02 13:59:56.965|CC|OFFERED|53236361|53236364|18882061454|911|911|SEP002414B33E40|SIP_Trunk_NACC_Montreal01
2015/02/02 13:59:56.965|SIPT|53236364|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_Montreal01|10.18.201.5|5060|2,200,21,1.7537875^10.116.131.14^RP_NACC_911|1669455|ac2da380-4cf1c92c-15c1e-1283740a@10.116.131.18|INVITE
2015/02/02 13:59:56.970|CC|RELEASE|53236362|0|0
2015/02/02 13:59:56.982|SIPT|53236364|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_Montreal01|10.18.201.5|63575|3,100,230,1.253733^10.18.201.5^*|1669460|ac2da380-4cf1c92c-15c1e-1283740a@10.116.131.18|100 Trying
2015/02/02 13:59:56.982|SIPT|53236364|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_Montreal01|10.18.201.5|63575|3,100,230,1.253734^10.18.201.5^*|1669461|ac2da380-4cf1c92c-15c1e-1283740a@10.116.131.18|403 Forbidden
2015/02/02 13:59:56.982|SIPT|53236364|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_Montreal01|10.18.201.5|5060|3,100,230,1.253734^10.18.201.5^*|1669462|ac2da380-4cf1c92c-15c1e-1283740a@10.116.131.18|ACK
2015/02/02 13:59:56.987|SIPT|53236364|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|5060|3,100,230,1.253734^10.18.201.5^*|1669463|ac2da380-4cf1c92c-15c1f-1283740a@10.116.131.18|INVITE
2015/02/02 13:59:56.988|SIPT|53236364|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|32785|3,100,230,1.253735^10.116.129.109^*|1669464|ac2da380-4cf1c92c-15c1f-1283740a@10.116.131.18|100 Trying
2015/02/02 13:59:57.023|SIPT|53236364|UDP|IN|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|32785|3,100,230,1.253737^10.116.129.109^*|1669467|ac2da380-4cf1c92c-15c1f-1283740a@10.116.131.18|404 Not Found
2015/02/02 13:59:57.023|SIPT|53236364|UDP|OUT|10.116.131.18|5060|SIP_Trunk_NACC_CUSPIntA5_CPODC1|10.116.129.109|5060|3,100,230,1.253737^10.116.129.109^*|1669468|ac2da380-4cf1c92c-15c1f-1283740a@10.116.131.18|ACK
2015/02/02 13:59:57.038|SIPL|53236361|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|2,100,13,32.125932^10.116.131.19^ANN_CPODC1|1669469|002414b3-3e4000e0-fcac178b-dd5d511e@10.16.244.26|183 Session Progress
2015/02/02 13:59:58.747|SIPL|53236361|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468965^10.16.244.26^*|1669474|002414b3-3e4000e0-fcac178b-dd5d511e@10.16.244.26|CANCEL
2015/02/02 13:59:58.748|SIPL|53236361|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468965^10.16.244.26^*|1669475|002414b3-3e4000e0-fcac178b-dd5d511e@10.16.244.26|200 OK
2015/02/02 13:59:58.750|SIPL|53236361|TCP|OUT|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468965^10.16.244.26^*|1669476|002414b3-3e4000e0-fcac178b-dd5d511e@10.16.244.26|487 Request Cancelled
2015/02/02 13:59:58.750|CC|RELEASE|53236361|53236364|1
2015/02/02 13:59:58.769|SIPL|53236361|TCP|IN|10.116.131.18|5060|SEP002414B33E40|10.16.244.26|49294|3,100,63,1.468966^10.16.244.26^*|1669477|002414b3-3e4000e0-fcac178b-dd5d511e@10.16.244.26|ACK
As suspected toll-fraud prevention on IOS is blocking the call, see "CCAPI handed cid 51533 with tag 3002 to app "_ManagedAppProcess_TOLLFRAUD_APP""
you have 3 options:
1. add another redundant dial-peer with preference 1, etc that points to the other sub (you need this anyway in case your sub-1 fails for inbound calls to work)
2. Add sub-2 IP under trust list
3. Add "no ip address truster authenticate" to disable toll-fraud feature (not recommended).
10 Replies 10
Chris Deren
Do you have the IP address of Sub2 defined as trusted IP in the voice gateway?
Can you provide "debug ccsip messages" from the GW?
Hi Chris,
I don`t have the Sub_2 defined as trusted IP in the GW but I don`t have the Sub_1 defined either and when the phone is registered with Sub_1 the 911 call goes out. When the phone is registered with Sub-2 the call doesn`t even hit the GW. The debug ccsip message shows nothing.
MK
Do you have a dial-peer defined on the GW that has session-target of sub-1?
Do you get anything in the debug when phone is registered to sub-1?
Is the 911 non-working pattern pointing to the same route list as other working patterns?
Yes, a dial-peer is pointed to Sub_1 for the incoming calls (see  below)
dial-peer voice 3001 voip
 description ** Call to CUCM Subscriber 01 **
 preference 1
 destination-pattern 1514[2-9]......$
 session protocol sipv2
 session target ipv4:Sub_1
voice-class codec 1
 voice-class sip options-keepalive up-interval 5 down-interval 10 retry 1
 dtmf-relay rtp-nte
 ip qos dscp cs3 signaling
 no vad
Here`s the output of debug isdn q931 when the phone is registered to Sub_1 when dialing 911
000922: *Feb  2 22:18:35.255: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0x5 is 0x2 0x1, Calling num 5148581256
000923: *Feb  2 22:18:35.255: ISDN Se0/1/0:23 Q931: Sending SETUP  callref = 0x0088 callID = 0x8009 switch = primary-dms100 interface = User
000924: *Feb  2 22:18:35.255: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0088
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Display i = 0xB1, 'Paco 7962'
        Calling Party Number i = 0x2180, '5148581256'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '911'
000925: *Feb  2 22:18:35.339: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8088
000926: *Feb  2 22:18:35.343: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8088
        Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
000927: *Feb  2 22:18:37.139: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x8088
000928: *Feb  2 22:18:37.139: ISDN Se0/1/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0088
000929: *Feb  2 22:18:48.363: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0088
        Cause i = 0x8090 - Normal call clearing
000930: *Feb  2 22:18:48.391: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8088
000931: *Feb  2 22:18:48.391: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0088
Can you see if you get anything when running "debug voice ccapi inout" for the non-working call?
Yes they all point to the same RL. All I do is changing the DP in the phone
DP1  points to GM_CM1 = Sub_1 and Sub_2
DP2 pints to GM_CM2 = Sub_2 and Sub_1
In the same phone when DP is DP1 everything works but as soon as it`s pointed to DP2 only 911 calls fail.
Here`s the output of debug voice ccapi inout:
000940: *Feb  2 22:34:07.387: //-1/857E65800000/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=15148581256
   ----- ccCallInfo IE subfields -----
   cisco-ani=15148581256
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=911
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
000941: *Feb  2 22:34:07.391: //-1/857E65800000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3167E110, Call Info(
   Calling Number=15148581256,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=911(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3002, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=51533
000942: *Feb  2 22:34:07.391: //-1/857E65800000/CCAPI/ccCheckClipClir:
   In: Calling Number=15148581256(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000943: *Feb  2 22:34:07.391: //-1/857E65800000/CCAPI/ccCheckClipClir:
   Out: Calling Number=15148581256(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000944: *Feb  2 22:34:07.391: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000945: *Feb  2 22:34:07.391: :cc_get_feature_vsa malloc success
000946: *Feb  2 22:34:07.391: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000947: *Feb  2 22:34:07.391:  cc_get_feature_vsa count is 1
000948: *Feb  2 22:34:07.391: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000949: *Feb  2 22:34:07.391: :FEATURE_VSA attributes are: feature_name:0,feature_time:805408392,feature_id:47
000950: *Feb  2 22:34:07.391: //51533/857E65800000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=15148581256(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=911(TON=Unknown, NPI=Unknown))
000951: *Feb  2 22:34:07.391: //51533/857E65800000/CCAPI/cc_process_call_setup_ind:
   Event=0x32101B08
000952: *Feb  2 22:34:07.391: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 911
000953: *Feb  2 22:34:07.391: //51533/857E65800000/CCAPI/ccCallSetContext:
   Context=0x2C610150
000954: *Feb  2 22:34:07.391: //51533/857E65800000/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 51533 with tag 3002 to app "_ManagedAppProcess_TOLLFRAUD_APP"
000955: *Feb  2 22:34:07.391: //51533/857E65800000/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000956: *Feb  2 22:34:07.391: //51533/857E65800000/CCAPI/ccCallDisconnect:
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
000957: *Feb  2 22:34:07.403: //51533/857E65800000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3167E110, Tag=0x0, Call Id=51533,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
000958: *Feb  2 22:34:07.403: //51533/857E65800000/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
000959: *Feb  2 22:34:07.403: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000960: *Feb  2 22:34:07.403: :cc_free_feature_vsa freeing 30018E80
000961: *Feb  2 22:34:07.403: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000962: *Feb  2 22:34:07.403:  vsacount in free is 0
MK
you have 3 options:
Thanks 1000 times my firend!!!!
I added a redundnat dial-peer and It worked!!!!
But I don`t understand what adding an inbound voip dial-peer has to do with an outbound 911 call???? Would you mind axplaining this?
Many TAHNKS,
MK
Having an IP address on any dial-peers tells the IOS that it's secured IP and automatically adds it to the trusted list.
Many thanks Chris
MK
