ccm-manager stays down after reboot or power cut
Hi!!
I have a gateway with mgcp configured to a CCUM. Everything is working fine but when a reboot is made or a power cut is done the ccm-manager stays down until I do the command "no mgcp" and then "mgcp".
My CCUM is 12.5 and my gateway uses 16.11.01a.
Some configs are:
mgcp
mgcp request timeout 1000
mgcp call-agent 172.17.50.130 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
mgcp bind control source-interface GigabitEthernet0/0/0
mgcp bind media source-interface GigabitEthernet0/0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/0
sccp
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config server xxx.xxx.xxx.xxx
ccm-manager sccp local GigabitEthernet0/0/0
controller E1 0/1/0
clock source line primary
pri-group timeslots 1-31 service mgcp
controller E1 0/1/1
clock source line secondary
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no cdp enable
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
trunk-group ALL_PRI
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
trunk-group ALL_PRI
Can you help on put this working in automatic mode?
Best regards,
Jose Carlos
HARIS_HUSSAIN
Try Adding ccm-manager redundant-host XXXXX.
The configuration looks good, Try with different IOS Version.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Hi!!
Thanks for your answer.
This is the latest IoS available and the only that works with SRST without freezing the CUBE if you try to transfer a call on SRST mode :(
Best Regards,
Jose Carlos
Ratheesh Kumar
Hi there
Sounds like a bug to me. There was a case similar to voice-ports getting shut down. Try a call with TAC, I suggest!
Voice interface may be in shutdown state after GW is reset from CCM
CSCed39983
Description
Symptom:
Voice interfaces such as FXS/FXO/PRI interfaces may be in
shutdown state after the IOS MGCP Gateway is reset from CallManager.
Condition:
This problem is observed only when "ccm-manager config" is
configured in the IOS MGCP Gateway.
Work-around:
Manually un-shutdown ("no shutdown") the voice interface.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Thanks !!
