CCM - rejected call still ringing
Ivan Marinovic
I have call Manager 7.1.5 . I noticed that when I call from phone (on CCM) to mobile phone, and if I reject call on mobile phone, phone (on CCM) is still having same sound in headphone (waiting user to accept call).
What cause that? What option do I need to check?
THX,
IVan
10 Replies 10
manpreetsingh46
Please answer the following questions.
1. Is it happenig with all the calls to mobile phone throug all gateways or just one specific type (MGCP, H323) Please also mention if we are using PRI or its voip to voip.
2. Was this working fine before?
3. Did you or ISP made any changes?
Can you collect detailed call manager traces for the call and also mention the Calling and called party information. ring back is played by the CCM for PSTN  calls when we get the ringing signal. We need to  verify if PSTN is sending is any signal to let us know if the calls is not answered.
also collect following debugs if we are using H323
debug isdn q931 (for PRI)
Debug h225v asn1
1. This is happening on SIP trunk (without CUBE). We have other two provider and i test and it is same situation...
2. No.
3. I contact them but still no response from them.
One college who work with Asterisk told me that i need to check is ring back played by ccm and maybe there i can adjust some option? whera/can that be checked.
I will collect traces on monday because today i am finish with work.
Ivan
Hi Ivan,
Thanks for the info. Please send me the traces at manpreetsingh46@gmail.com or attach those to this thread.
mohamed helmy
Hello Ivan,
if you are using FXO, you just need to check the "timing gardout 500" command under the FXO port at the VGW
Mohamed Helmy
Regards, Mohamed Helmy
Hi Mohamed,
we are using SIP trunk direct from provider to our CCM.
Reards,
Ivan
Collect CUCM traces and send to us..
Please rate all useful posts
traces are added:
number on CCM: 689885
Number called: 09156362XX (my mobile phone)
PLEASE RENAME 1.txt to 1.zip!
I did 3-4 test calls...
For test purpose (one call) i set gsm phone on (flight mode) no network. and usually when you call that phone auto voice told you some message but i did not hear any sound message, phone did not beep...  it was like dead :-)
Please help.
Ivan
manpreetsingh46
Digits were dialed endblock
03/31/2014 07:16:57.247 CCM|StationInit: (0000902) EnblocCall calledParty=00915636231.|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,39,1.12204775><IP::10.1.8.150><DEV::SEP00270D3E0572><LVL::State Transition><MASK::0020>
Digits analysis
03/31/2014 07:16:57.248 CCM|Digit analysis: analysis results|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,39,1.12204775><IP::10.1.8.150><DEV::SEP00270D3E0572><LVL::State Transition><MASK::0800>
03/31/2014 07:16:57.248 CCM||PretransformCallingPartyNumber=689885
|DialingPartition=METRONET_PT_PSTN_GSM
|DialingPattern=0.09[125789]XXXXXXX
|FullyQualifiedCalledPartyNumber=00915636231
CI of the first LEG Ci=44044351
03/31/2014 07:16:57.248 CCM|Digit analysis: insert daResEntry to daResCache. KeyCi=44044351 ,PID:Cdcc(2,175,9834)|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,39,1.12204775><IP::10.1.8.150><DEV::SEP00270D3E0572><LVL::Arbitrary><MASK::0800>
CI for the Second Leg CI = 44044352
03/31/2014 07:16:57.250 CCM|RouteListControl::idle_CcSetupReq -  RouteList(RL-METRONET), RouteListCdrc::create  CI = 44044352  BRANCH = 0|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,39,1.12204775><IP::10.1.8.150><DEV::SEP00270D3E0572><LVL::Error><MASK::1000000>
03/31/2014 07:16:57.250 CCM|RouteList - RouteListName=''RL-METRONET'' CallableEndPointName=''65df5682-11fa-9cf2-49cb-09f8ca4a7b07'' routeListEnabled=''1''|<CLID::StandAloneCluster><NID::10.1.8.12><LVL::Detailed><MASK::0800>
03/31/2014 07:16:57.250 CCM|TDCLdb.hpp - CallManagerGroup - serverCount = 2|<CLID::StandAloneCluster><NID::10.1.8.12><LVL::State Transition><MASK::0800>
03/31/2014 07:16:57.250 CCM|TDCLdb.hpp - CallManagerGroup - nodeId = 2|<CLID::StandAloneCluster><NID::10.1.8.12><LVL::State Transition><MASK::0800>
03/31/2014 07:16:57.250 CCM|TDCLdb.hpp - CallManagerGroup - nodeId = 1|<CLID::StandAloneCluster><NID::10.1.8.12><LVL::State Transition><MASK::0800>
CI 44044353of the MTP getting invoked (assuming the MTP option is checked on the SIP trunk)
03/31/2014 07:16:57.253 CCM|MediaResourceCdpc(9276)::waiting_MrmAllocateMtpResourceReq - CI=44044353 Count=1 TryPassThru=0|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,39,1.12204775><IP::10.1.8.150><DEV::SEP00270D3E0572><LVL::Special><MASK::8000>
03/31/2014 07:16:57.253 CCM|MediaResourceCdpc(9276)::findDeviceGivenList - Name=MTP_2 type=1 isTRPMust=1 weight=0|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,39,1.12204775><IP::10.1.8.150><DEV::SEP00270D3E0572><LVL::Detailed><MASK::8000>
We send an invite to 10.56.0.13
03/31/2014 07:16:57.256 CCM|//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 10.56.0.13 on port 5060 index 477
INVITE sip:00915636231@10.56.0.13:5060 SIP/2.0
Date: Mon, 31 Mar 2014 05:16:57 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: "Metronet test" <sip:107807885@10.1.8.12>;tag=09aff83d-e35e-4126-b546-06154a359328-44044352
Allow-Events: presence, kpml
P-Asserted-Identity: "Metronet test" <sip:107807885@10.1.8.12>
Supported: timer,resource-priority,replaces
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Min-SE:  1800
Remote-Party-ID: "Metronet test" <sip:107807885@10.1.8.12>;party=calling;screen=yes;privacy=off
Content-Length: 206
User-Agent: Cisco-CUCM7.1
To: <sip:00915636231@10.56.0.13>
Contact: <sip:107807885@10.1.8.12:5060;transport=tcp>
Expires: 180
Content-Type: application/sdp
Call-ID: acc53000-3381fa49-2e02-c08010a@10.1.8.12
Via: SIP/2.0/TCP 10.1.8.12:5060;branch=z9hG4bK4c236c6eef91
CSeq: 101 INVITE
Session-Expires:  1800
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.1.8.12
s=SIP Call
c=IN IP4 10.1.8.11
t=0 0
m=audio 28886 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
03/31/2014 07:16:57.267 CCM|//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 10.56.0.13 on port 5060 index 477 with 303 bytes:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
We Received Ringing
SIP/2.0 180 Ringing
To: <sip:00915636231@10.56.0.13>;tag=0004c6f4000bc3b8
CSeq: 101 INVITE
Content-Length: 0
Call Manager sarted playing alerting to our Phone
03/31/2014 07:17:00.578 CCM|StationD:    (0000902) StartTone tone=36(AlertingTone), direction=0.|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,45,1.338168><IP::10.56.0.13><DEV::><LVL::State Transition><MASK::0020>
Now you pressed End call to disconnect the call
03/31/2014 07:17:05.322 CCM|StationInit: (0000902) SoftKeyEvent softKeyEvent=9(EndCall) lineInstance=1 callReference=44044351.|<CLID::StandAloneCluster><NID::10.1.8.12><CT::2,100,39,1.12204860><IP::10.1.8.150><DEV::SEP00270D3E0572><LVL::State Transition><MASK::0020>
If this is the call than we need Telco to send us message to disconnect the call.
Symptoms you mentioned this time are of no audio issue. Please explain the issue and Lets stick to one issue at this time.
Thank you for your time and explanations!
Yes that’s good call.
Before pressing end call, i reject call on my mobile phone but nothing happened.
I will contact them.
Ivan
Teleco told me that they check and that everything is ok at their side sad
