CCM Subscriber setup issue
thiru.vel10
Hi All,
The Subscriber file system got corrupted, So we tried to reinstalled the Subscriber using Cisco DVD, We have successfully installed the OS and provide the Publisher information in the Subscriber OS prompt. However the application is not loading and services are not started in the Subscriber
I am able to reach the publisher from subscriber without issue and  vise versa .
Please any one can help on this.
Device Model : Cisco MCS 7835
Version : 6.1
Subplisher :
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager [Not Running]
Warning: Service Manager need to be running for all Call Processing Applications
5 Replies 5
Browse to Cisco Unified Serviceability > Tools > Service Activation. Make sure that proper services are activated. You may use Set to Default.
HI Mohammed,
Unable to access the Subscribed Web console and So i have verified the Publisher serviceabiity all services are activated.
Service Name Activation  Status
Cisco CallManagerActivated
Cisco TftpActivated
Cisco Messaging InterfaceDeactivated
Cisco IP Voice Media Streaming AppActivated
Cisco CTIManagerActivated
Cisco Extension MobilityActivated
Cisco Extended FunctionsActivated
Cisco Dialed Number AnalyzerActivated
Cisco DHCP Monitor ServiceActivated
CTI Services
Cisco CallManager Attendant Console ServerActivated
Cisco IP Manager AssistantActivated
Cisco WebDialer Web ServiceActivated
Database and Admin  Services
Cisco AXL Web ServiceActivated
Cisco UXL Web ServiceDeactivated
Performance and Monitoring  Services
Cisco Serviceability ReporterActivated
Cisco CallManager SNMP ServiceActivated
Security  Services
Cisco CTL ProviderActivated
Restart the TOMCAT service from CLI after that try access you Sub from GUI
admin:utils service restart Cisco Tomcat
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Tried but no luck --
admin:
Tried to restart serviceablity, manager and cluster as well no luck
Did you do complete a DRS restore for that node after installing the platform?
Also, is there an available node license on the publisher? CCM will not start if it cannot checkout a node license from licensing manager on the publisher.
Is the database replicating properly?
Please remember to rate helpful responses and identify helpful or correct answers.
