02-17-2009 08:34 PM - edited 03-15-2019 04:18 PM
I am using CCM 4.3.
Is there any way I can Track , who does what configuration change in the CCM , using CCMAdmin tool.
02-17-2009 09:01 PM
no, at most MLA logs for to know who accessed, and that if you use MLA. if not then any change must be in the iis logs but they're not pretty or easy to understand
java
if this helps, please rate
02-17-2009 09:03 PM
thanks.
Can you please elaborate "MLA logs for to know who accessed, and that if you use MLA".
thanks
02-18-2009 07:36 AM
Multilevel Administration
simply like this, if you use CCMAdministrator to log you use MLA, if you use the server credential no MLA
java
