05-19-2007 07:20 AM - edited 03-14-2019 09:35 PM
Anyone out there have any tips on getting 5.x installed on a VMWare image. I am trying to set up a lab for testing apps?
05-19-2007 08:02 AM
Make sure that you select the guest operating system as Red Hat Enterprise Linux 3, selct 2 GB of RAM, 72 Gig HD.
As the source use the DVD Drive or select the ISO if you are going to use iso instead.
That's it.
HTH,
Chris
05-19-2007 07:36 PM
In addition to what Chris said, CM 5.x will install natively in VMWare as well. It will tell you that it is not a supported platform, but install just the same.
The other issue that you are going to run into is that you need to install a license for CM and DLU's for devices. Talk with your local Cisco office about getting their VMWare image or possibly helping you out with licensing as Cisco licensing *typically* doesn't allow you to register VMWare MAC addresses.
Jon
