ccme + sip provider
kern.jerome
I tried to connect my ccme 4.0 with a sip provider. I managed to configure it for outgoing calls, but I'm unable to get incoming calls...
Can sombody show me how it works ?
19 Replies 19
gogasca
Level 10
Level 10
Configure an incoming dial peer which match codecs used by your provider.
For example:
dial-peer voice 4001 voip
voice-class codec 1
incoming called-number 5...
dtmf-relay rtp-nte
Where 5... are your extensions and in class codec you have:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
Thanks, but my provider send me a 10 digits number and I want to transalte it in a number like 2..
Just configure the 10 digits number as secondary in the corresponding ephone-dn. You can also configure sip-ua and it will register this number (no-reg primary) to the ITSP.
Then, "debug ccsim message" is your friend and will tell you what the ITSP is sending, and why is rejected.
You can create a translation rule like the following:
Lets say your provider sent you:
919 991 5454
voice translation-rule 100
rule 1 /^919....\(...\)$/ /\1/
voice translation-profile TOEXT
translate called 100
dial-peer voice 2000 voip
translation-profile incoming TOSIP
session protocol sipv2
dtmf-relay rtp-nte
codec g711ulaw
This should do it.
Number converted will be 454
or use:
dialplan-pattern command
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_administration_guide_chapter09186a00801f12a8.html#wp2261346
Again, the voice translation-rule, although a very powerful tool, is not necessary in this case.
The secondary number in ephone-dn, is instead what the CME architecture gives you to easily route call coming in as "pots" numbers.
Here you can see part of my configuration. It still don't work...
The dial-peer 3 should the one which is used for incoming calls ...
dial-peer voice 1 voip
translation-profile outgoing OutgoingProfile
destination-pattern T
session target ipv4:213.161.201.200
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 2 voip
destination-pattern 8..
session target ipv4:10.10.0.33
session transport tcp
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 3 voip
incoming called-number 0877192763
dtmf-relay rtp-nte
codec g711alaw
sip-ua
authentication username login password ****
sip-server ipv4:213.161.201.200
notify telephone-event max-duration 500
ephone-dn 1 dual-line
number 200 secondary 0877192763 no-reg primary
can you post output of "debug ccsip message" ? You will need of course "term mon" to see it on a telnet connection.
Dial-peer 3, being an incoming only, does not even need "session protocol", but I'm not sure if this is the problem.
I get no messages from a debug command using a console connection.
I will phone the provider to see if he can see something wrong ...
You must be able to see debug output, that is key to working with routers. Telnet to the router, and type "terminal monitor" before or after the debug commands.
I can show debug, but only during outgoing calls... nothings appears during an incomming call. That's why I'm trying to find a solution directly with my provider.
I'll let you know
Possibly you need to register with ITSP ro receive incoming calls. Create a "voice register dn" with the number that ITSP wants to be registed and a register server in sip-ua.
Woops, I see that your local phones are SCCP. Then no "voice register dn" is necessary, just "registrar" under "sip-ua".
Thanks for help !
Everything is working now.
Another question..
If I configure my cisco like you said, the ephone-dn registers the phone number with the secondary line.
Is possible to register with a dial-peer or something else to use hunt-groups ?
