10-23-2009 01:15 AM - edited 03-18-2019 10:45 AM
Within C2821-H-VSEC/K9 bundle, there is a CCME/SRST license, what's the difference with C2821-VSEC-CCME/K9 bundle's FL-CCME-50 license?
10-23-2009 01:39 PM
They both include a 50 user CCME/SRST license and a PVDM32 but the C2821-H-VSEC/K9 ($8,295 list) also includes an AIM-VPN/SSL-2 VPN module which bought separately would cost $2,500. this explains the cost difference over the C2821-VSEC-CCME/K9 which costs $6,395.
Please rate if helpful.
10-25-2009 06:18 PM
Thanks jamesha. For CCME function, what's difference between the two bundles?
10-26-2009 05:52 AM
There is no difference in functionality. You can run full CME (or SRST) with either bundle as the licenses are interchangeable - the Q-A below is from the document at the link below and confirms this.
Q. Are there any pricing differences between Cisco Unified Communications Manager Express and Cisco Unified SRST?
A. No. The feature license pricing is the same and interchangeable between Cisco Unified Communications Manager Express and Cisco Unified SRST.
10-25-2009 09:22 PM
If I can add the follwing may be of help to WO Chong or others.
The main function / limitation is VPN
C2821-H-VSEC/K9
Cisco 2821 HVSEC Bundle with IOS Advanced IP Services, PVDM2-32, AIM-VPN/SSL-2, 50 User SRST License, 10 User SSL VPN License, 256 MB Flash/512 MB DRAM
C2811-H-VSEC/K9
Cisco 2811 HVSEC Bundle with IOS Advanced IP Services, PVDM2-16, AIM-VPN/SSL-2, 35 User SRST License, 10 User SSL VPN License, 256 MB Flash/512 MB DRAM
C2801-H-VSEC/K9
Cisco 2801 HVSEC Bundle with IOS Advanced IP Services, PVDM2-8, AIM-VPN/SSL-2, 25 User SRST License, 10 User SSL VPN License, 128 MB Flash/384 MB DRAM
C2801-VSEC/K9
2801 Voice Security Bundle, PVDM2-8, Adv IP Serv, 64F/256D
C2801-VSEC-CCME/K9
2801 VSEC Bundle with PVDM2-8, FL-CCME-24, Adv IP Serv, 128F/256D
Please rate helpful posts
Thaks,
Baseer.
10-26-2009 12:39 AM
Thanks Baseer.But I can see CCME/SRST license from C2821-H-VSEC/K9 list price.CCME/SRST license has all function of CCME?
