CCME - Time is an hour out on voicemail messages
andy_4578
Is anyone aware of a bug with CCME version 7.1 and the voicemail time?
The router time is correct and so is the service module time.
The service module points to the router for NTP
Rebooting the entire system corrects the problem for an hour and then it goes an hour out again.
clileikis
Level 7
Level 7
Hi Andy,
I assume you're using a CUE module for your voicemail, is the timezone set correctly on the CUE module?  This can be changed using the 'clock timezone' command from the CLI.
HTH,
Chris
It's all sorted, the timezone was set to 22, changed it to 21 and updated the cnf-files
Great, glad it's working!  If you found any posts useful, please rate them.
Chris
