CCMUser Password Update error
mtashiro
When using CCMUser, the user tries to change their password. When then try to save they get the following error:
missing key in referenced table for referential constraint (informix.tk_enduser_tklocale)
The kicker is the password is actually updated and everything works.
Has anyone seen this issue before?
mtashiro
It's working now. Change the Locale from none, saved and now the error is gone.
Thank you for finding the fix Mark! A user just brought this to my attention this morning. To clarify; under the end user configuration, change the User Locale field from "none" to what ever you may be using (in my case it's "English, United States").
