CCUM 10.5 upgrade to 12.5 on UCSC-C220-M4S with ESX 5.5
AdamG73545
VMW-VS5 -HYP-K9 is expired and I wonder if I need that for 6.x upgrade.
1. Is free license will work?
2. VMW-VS5 -HYP-K9 is needed for TAC case if any issue?
3. Can VMW-VS6 -HYP-K9 be purchased instead of VMW-VS5 -HYP-K9 reneweal?
Thank you
7 Replies 7
1. Is free license will work?  You need to license the Vmware.
2. VMW-VS5 -HYP-K9 is needed for TAC case if any issue? You can Only Raise case if you have valid smartnet for your hardware
3. Can VMW-VS6 -HYP-K9 be purchased instead of VMW-VS5 -HYP-K9 reneweal? If you renew the Smartnet for Be6K , it includes VMware license too.Once renewed  Place the  Vmware upgrade though MCE portal .
Response Signature
So the free license will work for ESXi6.X ? I am confused. I dont see any special features. My BE6K has support but for unknown reason VMW-VS5 -HYP-K9 is expired under the contract for Be6. I plan upgrade and wonder if I should cancel it until I receive VMW-VS5 -HYP-K9 or I can use free relicense for ESXi6.7
You need versions 6 license if are upgrading to 6.X.versions 5 license won't work with v6.
What you mean by free license  ?
Response Signature
You can try the free license.. Be6K uses OEM license.
Response Signature
in my case BE6 has smartnet but with expired VMWARE so I have no idea what to do now, just try free license for esx 6 or buy from vmware license
If you renew the smartnet for Be6K, AFAIK the Vmware contract also gets renewed. Unless that versions has reached EOL.
Response Signature
