CCUM 10.5.x DNS unreachable
sprintership-il
Beginner
Beginner
Experts,
Since the beginning when we set up CCUM we deal with DNS unreachable message on CCUM. I think all is ok with our DNS's (windows based).
Thank You
2 Accepted Solutions
Seems that new DNS checks in later versions of CUCM complain about duplicate DNS entries. Looks like a bug, but I suppose it is normal behavior. Delete one of the two entries pointing to the publisher.
Brandon
Reason i wanted you to do the "utils diagnose test" is it tests both forward \ revers DNS, you should just fix the DNS entry on DNS server CUCM would take care if itself.
(Rate if it helps)
JB
14 Replies 14
Brandon Buffin
Can you verify that CUCM has the correct DNS servers? Use the command "show network eth0" from the CLI.
Brandon
Thank you Brandon,
I have SSH-ed to CCUM and from console
admin:show network eth0:
Ethernet 0
DHCP : disabled Status : up
IP Address : 192.168.100.100 IP Mask : 255.255.255.000
Link Detected: yes Mode : Auto disabled, Full, 10000 Mbits/s
Duplicate IP : no
DNS
Primary : 192.168.100.25 Secondary : 192.168.100.38
Options : timeout:5 attempts:2
Domain : localdomain
Gateway : 192.168.100.1 on Ethernet 0
Are these the correct DNS servers? Can you ping them from CUCM with this command:
utils network ping 192.168.100.25
yes both are pingable from CCUM
Jitender Bhandari
can you attach output of "utils diagnose test" from CUCM
JB
is that utils diagnose test will affect somehow performance? Asking because this is production environment ....
Thank You
admin:utils diagnose test
Log file: platform/log/diag5.log
Starting diagnostic test(s)
test - disk_space : Passed (available: 7189 MB, used: 12440 MB)
skip - disk_files : This module must be run directly and off hours
test - service_manager : Passed
test - tomcat : Passed
test - tomcat_deadlocks : Passed
test - tomcat_keystore : Passed
test - tomcat_connectors : Passed
test - tomcat_threads : Passed
test - tomcat_memory : Passed
test - tomcat_sessions : Passed
skip - tomcat_heapdump : This module must be run directly and off hours
test - validate_network : Reverse DNS lookup mismatch
test - raid : Passed
test - system_info : Passed (Collected system information in diagnostic log)
test - ntp_reachability : Passed
test - ntp_clock_drift : Passed
test - ntp_stratum : Passed
skip - sdl_fragmentation : This module must be run directly and off hours
skip - sdi_fragmentation : This module must be run directly and off hours
Diagnostics Completed
The final output will be in Log file: platform/log/diag5.log
Please use 'file view activelog platform/log/diag5.log' command to see the output
I have checked my DNS for main CCUM and looks like I have two HOST(A) records for same IP ccm1 and callmanager have same IP, ccm2, cuc1 and cuc2 are different.
Should I delete callmanager ? Or should I create alias to callmanager ?
Brandon
Thank you Brandon, is there any way to refresh dns on ccum? I have created an alias to callmanager pointing to ccm1. But message still there.
I would rather not reboot ccum. Thank You
(Rate if it helps)
JB
thank you, what about if I just delete all entries for ccum and cum and recreate them, just curious if that helps - if this is really DNS not bug on ccum side.
nevermind, the message just disappear, looks like dual entry for ccum caused that,
deleting one of them and creating an alias fix the issue, Thank you all for help.
Have a nice weekend !!!
I have the same Warning: DNS Unreachable on my Unity server.  I ran the show network eth0 and it shows the correct DNS servers and both are pingable from Unity.  I recently upgraded from 10.5.1 to 10.5.2
I ran the utils diagnose test.  See the below results
Log file: platform/log/diag1.log
test - disk_space : Passed (available: 27154 MB, used: 8857 MB)
test - validate_network : Forward DNS lookup failed
test - ntp_reachability : Warning
The NTP service is restarting, it can take about 5 minutes.
test - ntp_clock_drift : Warning
The local clock is not synchronised.
None of the designated NTP servers are reachable/functioning or legitimate.
test - ntp_stratum : Warning
The final output will be in Log file: platform/log/diag1.log
Please use 'file view activelog platform/log/diag1.log' command to see the output
