04-03-2014 08:09 AM - edited 03-16-2019 10:21 PM
Hi guys,
I'm working on a project for a business implemention of Cisco Unified Communication BE6K
and i'm using Gateway Router 2911 connected to the PSTN, and i need to implement the DID functionality
in a way that the mapping of DN(Directory Numbers) and DUN( Dialed User Number) incoming from the PSTN will be dynamic.
Classic Mapping :
DN(Extensions) | PSTN Dial User Number |
1001 | 5555-1001 |
1002 | 5555-1002 |
What i’m looking for :
1015 | 5555-1001 |
1020 | 5555-1002 |
And i can be able to change it easily to depending on the client need
1100 | 5555-1001 |
1500 | 5555-1002 |
Note: the problem here is not the limited range of DIDs so you would say that the solution is an Attent(CUAC).
Thank you.
04-03-2014 08:59 AM
I am sorry to have to tell you that the only feasible solution is to have an auto attendant that will route calls. There is nothing that can do what you want. You cant just dial a number and have it dynamically routed to a number without pre configuring that number of having an intermediary to route calls to that number
04-03-2014 09:13 AM
No, i don't say without preconfiguring.
what i'm saying is that if i need it to be configured, it will have to be at a higher level say an interface that someone with no IT exp will do it. then he or she will be able to point a DIDx>>>DNx just witha click of button.
and when the calls for DIDx comming it will direclty routed to DNx (no attendant). just the prehighconfig.
because i know that everytime i need to change the config i need to change the GW config which is not practical, i already done it on another Technology (Alcatel-Lucent) but i need it now on Cisco :)
04-03-2014 09:39 AM
Well..If you are looking at changing this on the gateway then users cant do it. Cisco gateways doesnt have a user interface for such things unless you are using CCME, then users can make changes from the web portal
04-03-2014 12:26 PM
You could write some sort of AXL or CURRI application with a web front-end that people could use to manage the call routing in a user-friendly interface.
