Community Helping Community
350
Beginner
CCX configuration
Dear Friends...
i have CUCM 6.1.3 and now i got a new requirment to configure CCX 7 with this call manager. Can any one please give me some idea how to do this. i know there are loads of information available on internet or docs. but i have some bad time lines to finish this . if some one can guide me .. steps or things to consider or take care when configuring this
Please share the steps to configure this.. clients need to record the calls. is there any kind of licensing . Is ther any compatibility issue with the versions of call manager and CCx version
thanks for giving time to this
happiness always
Jatin
1 REPLY 1
CCX configuration
for UCCX integration with CUCM you need to obtain the relevant licence
license for number of ports
license for the UCCX/IVR server
if have it in HA two server you need HA license
you need to make sure what type of recording supervisor recording or call recording for every call if the later one then you need QM server and license for QM into UCCX
for the integration you can refer to the cisco guide of installing and integrating UCCX which is more than enough
if helpful Rate
Content for Community-Ad
FusionCharts will render here
