cdr and missed calls
bluesea2010
Level 5
Level 5
is there a way to get a list missed calls for a particluar number
from cdr or any otherway
If you have the service parameter 'CDR Log Calls with Zero Duration Flag'
turned on, then you can get missed calls from CDR. Unanswered calls will be
logged with zero duration.
**** please remember to rate useful posts.
Exactly what Mohammed mentioned - allow calls with 0 duration to be logged, then use a cdr / reporting tool to view these calls.  I've written the free software VoIP Detective - which can do this for you without issue.
I just enabled  CDR Log Calls with Zero Duration Flag  but did it not sync to the subscriber .Can I enable it on manually on the subscriber
Or is there a way to fix out of sync parameter ?
