CDR confidentiality on CUCM 9.0
gianandrea
Hello everyone,
I have a question regarding confidentiality of CDR information stored on CUCM 9.0 server, for the time going from CDR creation and its export to the external billing server. How can I make sure this information cannot be accessed by any unauthorised user?
Thanks a lot in advance for your support.
Gian Andrea.
2 Accepted Solutions
paolo bevilacqua
It cannot be accessed, same as anything else on CM when you do not have the admin access.
Unless you have access to the CLI, CAR or via AXL, there's no way someone can read the CAR info.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
5 Replies 5
paolo bevilacqua
java
java
Thank you Jaime for your feedback.
Grazie Paolo per il riscontro.
Thank you for the nice rating and good luck!
