CDR Field "originalcalledpartynumber"
Hi, I have this DDI 91381111 , there is a translation pattern for this 91381111 -> 805, being 805 the pilot for a hunt list.
I need to know how many incoming calls I had on 91381111 there is a translation pattern applied, the CDR field
originalCalledPartyNumber Text String      This field specifies the number to which the
                                                            original call was presented, prior to any call
                                                            forwarding. If translation rules are
                                                            configured, this number reflects the called
                                                            number after the translations have been
                                                            applied.
                                                            This field represents a numeric string of up
                                                            to 48 characters that can be either digits or
                                                            a SIP URL.
                                                            Default - empty string "". If destination
                                                            cannot be reached, this field stays empty.
Since the number appear after the translations, how can i find out about these calls?
Thanks in advance
Cesar.
