CDR push to FTP server failing
MBrooksAirIT
Hello- We have a 24/7 schedule to push CDR records to an FTP server from our CUCM Publisher. We changed the FTP server IP and I updated this under Serviceability > CDR Management. However, no CDR files are getting pushed. I verified the schedule is still configured 24/7 CAR > System > Scheduler > CDR Load. Both Continuous Loading 24/7 and Load CDR Only are checked. I can FTP a file from a client in the same subnet as Pub.
Any ideas?
CUCM v6.1.4
Windows FTP Server
Load CDR only
Thanx
Use file get command to try to download a file to that server
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
MBrooksAirIT
Corollary to this, how can I test FTP directly from the Pub? SSH to Pub and I do not see an FTP option anywhere.
java
java
Thank you. The options I see are:
admin:file get
      file get activelog
      file get inactivelog
      file get install
      file get partBsalog
      file get salog
      file get tftp
To those who find this thread, I used this doc to figure out how to manually transfer files:
http://docwiki.cisco.com/wiki/Cisco_Unified_Presence%2C_Release_7.x_--_file_get_CLI_Command
Specific commands I ran:
file list activelog cm/cdr_repository/processed/
file get activelog cm/cdr_repository/processed/ recurs
And to resolve the original issue, I just completely deleted and re-added the new server.
