03-14-2019 11:41 AM
Hi!
I do have some issues finding CDR records for a specific client that use Jabber on Android phones.
Should this be supported?
They are actually 10.x and moving to 11.x soon on CUCM
Thanks for your help!
03-14-2019 01:03 PM
CDR records for Cisco Jabber for Andoid is supported, so you shouldn't have a problem.
Please can you check that you have assigned the user-ID for this device? This user ID gets recorded in the call detail record (CDR) for all calls made from this device.
G
03-17-2019 03:20 AM
