10-21-2011 06:12 AM - edited 03-16-2019 07:38 AM
I have a user that has no data when I run a CDR department report. I noticed they did not have an owner user id associated. So I went into CCM and associated the user. However, there is no data when I run the report again. Will I be able to get this report out or does this association only work going forward?
Solved! Go to Solution.
10-21-2011 06:29 AM
Hi there,
With changes like this in relation to CDR/CAR the update will not
be retroactive. So the user data will not be collected prior to the change
being implemented
Cheers!
Rob
10-21-2011 06:29 AM
Hi there,
being implemented
Cheers!
Rob
10-21-2011 07:31 AM
Thanks for clarifying Rob.
