06-02-2015 09:52 AM - edited 03-18-2019 11:33 AM
I have
Thanks.
Solved! Go to Solution.
06-03-2015 04:16 PM
Hi opnineopnine,
when you configure a gateway using SCCP, this info appears in CDR as SKIGW<last 10 characters of MAC> and with Module and Slot info that you configure in CUCM ... check your CDR for that info.
Hope this helps.
06-03-2015 02:39 AM
If you are using MGCP, the CDR should have the indication which E1 making the call.
06-03-2015 03:13 AM
Hello
06-03-2015 04:16 PM
Hi opnineopnine,
Hope this helps.
06-04-2015 06:17 AM
Marcelo,
Is there any software that you can recommend to read the output?
06-04-2015 09:04 AM
Hi opnineopnine,
although CUCM has a tool called CAR (check this link), I prefer to use Excel to read the CDR for this kind of things (like a quick look in one of its data).
The CUCM's CDR is in a .CSV format.
Hope this helps.
