Good Day,
Im hoping someone can help me with a CER issue Ive encountered. I dont have too much experience with it and am not sure if this is an issue on our side or something we have to work out with the carrier.
We have a remote site with an old odd-man-out phone system, which we are in the process of changing over to our current Cisco Phone system (CM 11.5).
CER has been in place and working on the Cisco system for some years, so all of the 912 and 913 foundation stuff is configured and working correctly.
I configured CER and the necessary route pattern. 1<10-dig-ELIN>.911 - route partition 'System CER' (on our system) - GW/RL - Emergency - which points to SLRG - Which verified points to correct GW.
I configured the conventional ERL and added the ALI details, and had the site manager verify the address and phone number.
I set up phone tracking and verified the site's cisco phones are appearing.
Ive read through https://community.cisco.com/t5/collaboration-voice-and-video/cisco-emergency-responder-cer-explained/ta-p/3138289
The issue is that when a 911 call is made from the old - non-cisco system, (which I believe is delivered via a local POTS), the call successfully goes to the local PSAP, and has the correct ALI: but the call from the cisco phone, while delivering exactly the same ELIN (Per the 911 operator, the CER record, and the CDR record), went to National and did not display an address. The Cisco call was delivered to the expected, remote, gateway.
My belief, perhaps erroneous, was that the PSAP did a lookup based on ELIN, and if the ELIN was the same, the rest would fall into place, and that was one of the jobs/advantages, of CER was to make 911 calls exiting a centralized site, look like they exited from the local site, therefore get local PSAP and pull the correct addr.
So my questions are,
1. is this something we need to work with the carrier on, or is it probably something on our end?
2. If the latter, where should I look?
3. Are my basic understandings correct:
a. If we deliver the correct ELIN the rest should fall into place
b. CER should make the 911 call look like it came from the
Hi Jonathan,
Thanks for the response. I believe you've hit the answer. In the case of the existing phone system, it would be routing the call out a local POTS to a small carrier - and it is a different carrier than is the centralized egress point.
We are reaching out to our carrier and I'll update the ticket when I know more
thx
