Walkthrough Wednesdays
1166
uwhler
Beginner
Certificate (MIC) on 9971/9951
Does the ip phones 9971 and 9951 have MIC (Manufacturer Installed Certificates).
If so, how do I get the public ca certificate of this MIC?
On the 7925G it can be downloaded via the phone's web interface, but there is no such menu option on 9971.
2 REPLIES 2
uwhler
Beginner
I'm still searching for an answer to this question
William Bell
Advisor
Yes, they do.
Sorry, I can't help you here.  I just saw that you were asking for a follow up and I figured I would give the same answer I would have initially.  Personally, I am not sure why you would need this information and it is recommended to replace the MIC with a new cert.  But I won't pretend to be the mac on the MIC.  Good luck.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Content for Community-Ad
Spotlight Awards 2021
