04-03-2013 04:29 AM - edited 03-16-2019 04:34 PM
I hold a CCNA certificate that will expire on June 4 2013. I plan to write CCIE Voice Written before that. My question is - will I be eligible to write CCNA Voice / CVP papers after I clear CCIE Voice Wrtitten? Or do I need to re take CCNA again?
Solved! Go to Solution.
04-03-2013 05:21 AM
Hi Rajnath,
Here you go
CCNA Routing and Switching certifications are valid for three years. To recertify, pass ONE of the following before the certification expiration date:
When using a higher level of certification to extend other certifications, the expiration date of other certifications will extend to the expiration date of the higher certification (i.e.: If you have one year left on your CCNA Routing and Switching certification and you earn a CCIE certification (which has a two-year certification life) then both your CCIE certification and your CCNA Routing and Switching certification will expire two years from the date you achieved the CCIE certification).
http://www.cisco.com/web/learning/certifications/associate/ccna/recert.html
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
04-03-2013 05:21 AM
Hi Rajnath,
Here you go
Cheers!
Rob
- Stones
04-03-2013 05:41 AM
Thanks a lot Rob really appreciate your help.
Best Regards,
Rajnath.
04-03-2013 06:02 AM
Hi Rajnath,
You are most welcome my friend Best of luck with
your upcoming studies!
Cheers!
Rob
- Stones
