I hold a CCNA certificate that will expire on June 4 2013. I plan to write CCIE Voice Written before that. My question is - will I be eligible to write CCNA Voice / CVP papers after I clear CCIE Voice Wrtitten? Or do I need to re take CCNA again?
Solved! Go to Solution.
Hi Rajnath,
Here you go
CCNA Routing and Switching certifications are valid for three years. To recertify, pass ONE of the following before the certification expiration date:
When using a higher level of certification to extend other certifications, the expiration date of other certifications will extend to the expiration date of the higher certification (i.e.: If you have one year left on your CCNA Routing and Switching certification and you earn a CCIE certification (which has a two-year certification life) then both your CCIE certification and your CCNA Routing and Switching certification will expire two years from the date you achieved the CCIE certification).
http://www.cisco.com/web/learning/certifications/associate/ccna/recert.html
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
Hi Rajnath,
Here you go
Cheers!
Rob
- Stones
Thanks a lot Rob really appreciate your help.
Best Regards,
Rajnath.
Hi Rajnath,
You are most welcome my friend Best of luck with
your upcoming studies!
Cheers!
Rob
- Stones
