07-29-2020 11:26 PM
Here's the scenario,
We have a DN, lets say (03 1111 2222) which we have configured a different CLI ( 03 1111 3333) using Calling Party Transformation when making any external Calls. We set that Transformation CSS at SIP Trunk Level.
In a scenario where it makes any externals Calls, the other party observes the Masked number
DN ( 03 1111 2222 makes PSTN call) > SIP Trunk > Mobile User (observes Caller ID as 03 1111 3333)
But In a scenario, where DN has set the CFA to mobile, it doesn't show the masked number
Incoming PSTN Call to DN 03 1111 2222 > CFA (Mobile 04 5555 6666) > SIP Trunk > Mobile User (observes Caller ID as 03 1111 2222)
Not sure if it is do with Calling Party Transformation should be done at Device level for this particular scenario
OR
It is to do with Calling Party Selection at SIP Trunk Level which is currently set as Last Redirect Number
OR
It is to do with SIP header manipulation at CUBE Gateway level
Would appreciate if we can get responses If someone has already been to this situation and knows what needs to be done.
Taha
Solved! Go to Solution.
07-30-2020 02:31 AM - edited 07-30-2020 02:32 AM
Another option and this will suit your request.
07-30-2020 02:06 AM
One option will be :-
