100
Highlighted
Beginner
CFNA from DX650 Cause One-way Audio
Hello All,
I am facing an issue in CFNA from a DX650. When a DX650 set to CFNA to the mobile number call is sent to the mobile. But when the call is answered it causes the one-way audio. We are using SIP trunk to connect to the provider.
Phone A (DX650) set CNFA to Mobile number - It is in Site A
Phone B (7821) the calling Device- It is in site B.
Phone B calls Phone A, the call is forwarded to the mobile number after 3 rings. The mobile phone answers the call. The mobile  phone user can hear the Phone B user but Phone B user cannot hear the mobile phone user.
I could see that the Sender Codec for this call from Gateway to the 7821 is G711a and the receiver Codec is G722.
When tried for this same scenario with 7861(instead of DX650) it works fine.  Both parties can hear each other and the Codec negotiated is G711a.
DX650 in Device Pool A (Uses Region Default)
7821 in Device Pool B (Uses Region Default)
SIP trunk to the CUBE in Device Pool GW (uses GW Region)
Region Config:
Default to GW:64Kbps (with G711a and G711u preferred over G722)
GW to Default: 64Kbps (with G711a and G711u preferred over G722)
Thanks and Best Regards
Abdul Rasheed
1 REPLY 1
Highlighted
Participant
Would it be possible for you to pull a working and non-working set of CCM traces and attach it here if not too big. I can try to have a look at it and comment further.
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
