cfwdall 2nd line of phone
lukeprimm
Using CME's, is there a way to cFWDall the 2nd button (2nd line)?  Our remote office's use button 2 as the office main number and would like to be able to forward it to an external when needed.  I enabled cfwdall on the phone but they report they can only forward the first button line, not the second.
thanks
Chris Deren
By default you do not get that ability, see this thread for some thord party solution:
https://supportforums.cisco.com/message/1238383#1238383
HTH,
Chris
Chris Deren
HTH,
Chris
