05-28-2019 05:15 AM
Solved! Go to Solution.
06-03-2019 05:01 AM
Let's see the config of that profile. Again, you're fighting the intended design of the protocol here so there is no guarantee this is going to work as you hope it does.
05-28-2019 08:58 PM
05-28-2019 10:27 PM
Thank Jonathan.
can you explain where I can change this value?
05-29-2019 06:05 AM
06-03-2019 01:33 AM
Hey Jonathan.
I did sip-profile.
I can see in debug ccsip messages the anonymous has changed to what I want.
but in the phone still get the "Anonymous" alerting name
06-03-2019 05:01 AM
06-03-2019 05:10 AM
request INVITE sip-header From modify "Anonymous" "1234"
request INVITE sip-header From modify "@anonymous.invalid" "1.2.3.4"
in addition I change the "RINGING" as well
06-03-2019 05:58 AM
06-06-2019 03:49 AM
Jonathan, Thank you very much!
In my environment, I got "Private" instead of "anonymous".
so under sip-ua I put "no remote-party-id" and then started to get "anonymous"
after that, I put those commands
voice class sip-profiles 1
request INVITE sip-header From modify "anonymous" "hidden number"
and apply it at "voice service voip" > sip > sip-profiles 1
