06-29-2022 01:40 PM
06-30-2022 12:20 AM - edited 06-30-2022 07:49 AM
If your located in USA and has a CM setup you need to deploy CER, Cisco Emergency Responder, to stay complain with the new regulations in Ray Baum's act and Karie's Law. You can read more on this link.
06-29-2022 02:07 PM
About anything is possible with the needed configuration in place. If you need help start by outlining some specifics about your call setup. For one what type of call service do you have, CM, CME or even WxC?
06-29-2022 02:28 PM
Sorry, right, left out some details there.
We are using CUCM and we configure e911 services through NexVortex. The ELIN within CUCM looks like it might be a good solution but I can't see the ELIN configuration page without enabling ELIN which makes me nervous because of the warning "Do not enable this feature if using an external emergency calling solution". I wish I could configure emergency locations prior to enabling it.
06-30-2022 07:46 AM
I see, thank you. We had this system installed less than 2 years ago. It's unfortunate the contractor did not include the CER.
