change CME ephone hold/auto-answer behavior for dual line
pengfang
I have a ephone-dn with dual-line, when the first line in use, the second call came into the same number. If I put first line on hold, the second line will be automatically answered.Can I just let the second line ring, but still put the first line on hold ?
Hi Peng,
I actually just filed a bug on this recently.
This is your bug: CSCsy99058
This should be fixed into the next 12.4(24)T release.
hth,
nick
paolo bevilacqua
Hi, not sure what exact IOS, phone model and FW you're using, byt what you described it is not normal operation.
When a 2nd call comes in you should have softkey presenting answer and hold choices separately.
Thanks for prompt answer. IOS is c3640-jsx-mz.124-5b.bin, 12.4(5b), Phone is 7960, no FW configured.
Yes, when a 2nd call comes in, I see the softkey presenting "answer" on line 2, but at this time, I scroll back to the 1st line and press "hold" , then the 2nd line which is ringing will be automatically answered. I know this make sense, when holding the 1st line, you intend to answer the 2nd call, but can I just let the 2nd line ring while holding the 1st line ?
Hi Peng,
hth,
nick
Thanks Nick, this really helps.
