change cuc language localles for all the users
monasir
Hi all,
I was able to install the language pack for cuc i can see it in show version as active.
I would like to know how can i apply the correct language pack for all the users instead of one by one.
Can i use i user template - voicemailtemplate and choose the correct language (dutch) ?
Jonathan Schulenberg
What about changing the system default language? I believe System Settings > General
Otherwise you could use Bulk Edit to update all existing mailboxes and the Subscriber Templates to set new mailboxes as they are created in the future.
