2042
johanbonvalet1
Beginner
Change default language of Ip phone on CUCM 10.5
Hello Everybody,
I have Aa CUCM 10.5 installed, and i need to change the default-language of a DX80 inside my cluster to French,
Someon know , how can i do that?
Thx in advance
2 ACCEPTED SOLUTIONS
The default language is set in System/Enterprise Parameters in CUCM.
You'll need to ensure you have installed the French locale file on all your CUCM server in the cluster.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
If you need to change locale to DX80 only, on phone configuration page, change the value User Locale if you previously installed French locale as correctly suggested by my buddy Aaron  + 5 :)
Carlo
Please rate all helpful posts "The more you help the more you learn"
3 REPLIES 3
Aaron
Carlo
Thanks!
we are about to install the combined newtork file and locale french file. Then we will see...
Create
Recognize Your Peers
Content for Community-Ad
