10-02-2022 12:20 PM
Good day all,
Have a 7811 cisco that originally came loaded with the enterprise firmware. ended up loading the mpcc firmware onto it and now don't find any option to revert back. Admin portal/under voice no tabs available for provisioning. stuck on this. any other way or is that device a dud going forward.
On a separate note, was testing out to see what options if any are available to hookup the cisco to another third party ucm and guess have learned it the hard way to not mess around.
Any advise would be very helpful.
Solved! Go to Solution.
10-02-2022 09:14 PM
thanks for the reply. i have managed to revert back to the old firmware. went to HTTP://ip of phone/admin/upgrader?tftp://ip/loads file and it did the work. the tabs in the article never showed the tabs mentiioned.
10-02-2022 01:01 PM
@rajkamath Please see below.
Also, I have heard, but not tested myself, that you can register to a MPP phone as a third party SIP phone to CUCM. Not sure, what limitations it would there would be if you can register this way.
10-02-2022 09:14 PM
