11-20-2014 05:03 AM - edited 03-17-2019 01:02 AM
Need to change current fax number from XXX-XXX-1234 to XXX-XXX-4321 on the FXS port on h323 Gateway, but the Caller ID should be displayed as XXX-XXX-1234
Current configs:
voice-port 0/2/1
station-id name Xerox Copier 1
station-id number XXXXXX1234
caller-id enable
Solved! Go to Solution.
11-21-2014 05:32 AM
Hi.
For incoming calls, sure you can.
For outgoing calls, no because the number is fixed on that line by Carrier.
Carlo
11-20-2014 05:09 AM
Hi.
If you mean the printed number that shows on fax received from a remote fax, you should be able change it directly on you fax machine and leave the voice port with current config
Carlo
11-21-2014 04:56 AM
Hi Carlo,
I will be changing station ID number but customer wants the old number to be displayed on the FAX machine, where customer will be sending fax to the old number XXX-XXX-1234 but it should be received on the new number XXX-XXX-4321, correct me if I amwrong, can I apply the below voice translation rules
voice-translation profile incoming fax
translate called 1
translate calling 2
voice-translation rule 1
rule 1 /XXX-XXX-4321/ /XXX-XXX-1234/
voice-translation rule 2
rule 2 /XXX-XXX-1234/ /XXX-XXX-4321/
11-21-2014 05:32 AM
Hi.
Carlo
