Yes
Customer Impact from New Licensing Procedures
Cisco Unified Communications Manager on VMware on Cisco UCS B-Series Blade Servers uses a different licensing model than Cisco Unified Communications Manager on an MCS server. The MAC address of the NIC card is no longer used to associate the license to the server.
Instead, the license gets associated to a license MAC, which is a 12 digit HEX value created by hashing the following parameters that you configure on the server:
Time zone
NTP server 1 (or "none")
NIC speed (or "auto")
Hostname
IP Address (or "dhcp")
IP Mask (or "dhcp")
Gateway Address (or "dhcp")
Primary DNS (or "dhcp")
SMTP server (or "none")
Certificate Information (Organization, Unit, Location, State, Country)
The ways to obtain the license MAC are as follows:
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
