Change order & rename buttons (label) on "directory page" possible? (7965 & 8841 Series)
OSPMMeyer
Is it possible to change the order and rename the buttons "1 / 2 / 3" on a "directory page"? I've only found a option to change the button order for specific "call states".
Chris Deren
Unfortunately No, as that is not exposed to administrator, you would need to point to custom directory XML service if you need more flexibility.
Thanks.
We actually use a custom XML Service URL for specific input fields, but i think there's no option to change the button layout from this xml.
