Change the foreground softkey on Ring-in CP-8865
iantra123
Level 3
Level 3
How can I change the foreground of my CP-8865 when an incomming call is ringing on this phone.
Because the softkeys are hidden behind this wall-"softkey".
I want that when a call arrives on the 8865, I want to see "Answer - Decline - Ignore - Divert" (to divert the call to the assistant)
I don't want to press "Ignore" then press the softkey "Divert"
CUCM Softkey template  is already good, but I have to press the button ignore to see the softkey that i've configured on the Softkey template. Is there any solution to avoid or update this popup ringing wall.
See the figure in attach about I want to have.
Antra
Jaime Valencia
You cannot change the actionable items, you'll only get answer, decline and ignore.
java
if this helps, please rate
