Change the Time of No Answer Ring Duration CUCM
matthewlogan46
In the CUCMv8, How I can change the default time in seconds to the parameter "No Answer Ring Duration" in the CUCM´s?
I need to change "no answer ring duration" to 20 seconds in all phones.
Thanks!
ronpatel
Level 8
Level 8
HI
It dould be Forward No Answer Time under Cisco CallManager service parameter.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
abarkalg
         Changing the number of times a Cisco IP Phone rings before  forwarding to voice mail or another station is accomplished by  changing a service parameter.
  1. From the Cisco CallManager Administration web pages, select Service > Service Parameters.
  2. Select Cisco CallManager from the list and then choose the Cisco CallManager service from the list on the left.The parameter that needs to be changed is titled Forward No Answer Timeout. By default, it has a value of 12 seconds. A typical ring cycle is approximately 4 seconds.
please rate helpful posts!!!
Abdul
matthewlogan46
Thanks !!!!
EmilTaghiyev
System - Service Parameters- CUCM Voice/Video - Cisco Call Manager (Active)
Change value of  Forward no answer
