04-13-2015 10:48 AM - edited 03-17-2019 02:38 AM
I recently completed an upgrade from 10.5, and need help changing the behavior of how phones answer calls on different lines.
Here's what's happening:
Phone gets a call on DN 1, and answers it.
The same phone gets a second call on the same DN (in a different partition, assigned multiple times to this phone, which is a receptionist desk that handles all incoming calls for the site's main number), and the user presses the second line button to answer it.
The first call is placed on hold.
Here's what I WANT to happen:
The same phone gets a second call on the same DN.
When the second call is answered, the first call is terminated.
As I understand it, what IS happening is the default behavior. But I can't figure out how to make it function the way I'm describing, and I know that it was possible in the past. I've played with the Max calls/Busy calls numbers, but that doesn't seem applicable to what I'm trying, and it messes with call transferring for some reason.
Any ideas?
04-13-2015 11:02 AM
I'm testing this on ccm 9.1 and the first call is placed on hold as well.
What ccm version were you using when the first call was terminated?
04-13-2015 11:05 AM
We were previously using 8.6.
Regardless of default behavior, is there a way to change this to what I'm describing?
04-13-2015 12:21 PM
There is no way to do what you're asking, the expected behavior is what you're seeing.
