12-12-2012 03:59 AM - edited 03-16-2019 02:41 PM
I am trying to change the Firmware to SIP on one of our Cisco 7911 Phones. I booted the phone and did the usual factory rest by pressing # then 123456789*0#
Now the phone tries to upgrade the firmware but then reboots.
What am i doing wrong please?
Solved! Go to Solution.
12-12-2012 05:54 AM
If you want to post the XML file and a file/folder listing of the TFTP server I'll take a quick look. Also what GET requests does the phone make to the TFTP server?
Not to sound dismissive but you're on the edges of what people will typically assist with on these forums. The knowledge here centers around how to make the endpoint work with the Cisco call control products. Since Cisco doesn't support or publicly document what you're attempting to do the instinctive reaction from most here will be to say 'not supported; have a nice day'. That's why sites such as voip-info.org exist.
12-12-2012 05:01 AM
What product: CUCM or CME? What server-side actions have you taken?
12-12-2012 05:03 AM
None, we are wanting to use SIP not Skinny.
I have setup TFTP and set option 66 in the DHCP. On the TFTP server i can see that the phone is communicating
12-12-2012 05:25 AM
Ah, sounds like you're trying to use this with a third-party SIP proxy/registrar? If that's the case you probably want to go look at voip-info.org; the answers here are usually limited to making a phone work with the Cisco call control products (both CUCM and CME support SIP phones in current releases).
http://www.voip-info.org/wiki/view/Setup+SiP+on+7940+-+7960
http://www.voip-info.org/wiki/view/Asterisk+phone+cisco+79x1+xml+configuration+files+for+SIP
At a very high level: You'll need the appropriate firmware package and then to build the XML file so the phone knows what firmware files to download. Once that's done you would then need another XML file to tell it about the SIP Proxy. Note that the phone is not strictly RFC3261 compliant; it uses a bunch of custom Cisco behavior so your millage may vary.
Please remember to rate helpful responses and identify helpful or correct answers.
12-12-2012 05:32 AM
Yep done all that. But this is really a Cisco issue as its getting the firmware on the dam thing.
12-12-2012 05:54 AM
12-13-2012 12:39 AM
Thanks for the help, please see the below. I didnt setup the directory, services etc buttons yet to be honest.
SIP cisco cisco D-M-YA UTC Standard/Daylight Time 2000 5060 5061 172.20.1.2 true true x--serviceuri-cfwdall x-cisco-serviceuri-pickup x-cisco-serviceuri-opickup x-cisco-serviceuri-gpickup x-cisco-serviceuri-meetme x-cisco-serviceuri-abbrdial false 2 true true 2 2 0 true 6 10 180 3600 5 120 120 5 500 4000 70 false None 1 false true false false 101 3 avt false false 3 1109 1 false 10 false 16384 32766
button="1">9 1109 172.20.1.2 5060 1109
1109 2 3 1109 zak123
false 1 700 4 5 1109 true false false true
button="2">21 speed dial name goes here speed dial actual number goes in here 5060 184 0 dialplan.xml true 2 SIP11.9-3-1SR1-1S
false false 0 1 0 0 0 0 1 1,2,3,4,5,6,7 00:00 00:00 00:00 1 1 1143565489-a3cbf294-7526-4c29-8791-c4fce4ce4c37 New_Zealand
New_Zealand 5.0(2)
1 http://www/ipphone/authenticate.php http://www/ipphone/directory.xml http://www/ipphone/GetTelecasterHelpText.jsp proxy:3128 http://www/ipphone/services.xml 96 0 96 4 0 3804
false
12-16-2012 07:00 AM
HI,
Just wondering if you managed to look at this xml please?
